- Jul 13, 2020
- Columbia, MO
- Automatic
I am working on a 1997 Ford Ranger XLT 4.0 liter OHV engine and trying to perform a cylinder leak down test on each cylinder. I have the firing order for my engine as, 1-4-2-5-3-6.
Compression readings from the compression test were the following:
Cylinder 1 175psi
Cylinder 2 170 psi
Cylinder 3 165 psi
Cylinder 4 150 psi
Cylinder 5 175 psi
Cylinder 6 165 psi
I am just trying to run a cylinder leak down test on each cylinder. I believe I can find cylinder one TDC, easily, but I get lost from there... Should I just simply count four notches on the harmonic balancer to get to cylinder 4 TDC from TDC of cylinder 1?
Suggestions? Thoughts? Recommendations?
Cylinder 1 175psi
Cylinder 2 170 psi
Cylinder 3 165 psi
Cylinder 4 150 psi
Cylinder 5 175 psi
Cylinder 6 165 psi
