- Sep 27, 2023
- Age
- 43
- Sugarcreek Ohio
- 4.0 V6
- Manual
- Total Lift
- 4 inch suspension 3 inch body
- Tire Size
- 33x12.50 R15
I need some help on this fuel rail, regulator, top plenum clearance issues. I’m doing a 99 non egr 4.0 OHV swap in my 97 egr 4.0 OHV. My 97 has the two fuel lines. The 99 has one line with a smaller regulator at the supply port. I swapped the 97 fuel rail on to the 99 so I had my return line. Now my non egr plenum is hitting the regulator and won’t bolt up. Has anyone else ran into this issue? Should I try to upgrade my fuel pump to the single line like the 99 or is there a way to modify the plenum to fit over the 97 regulator?
