1996 4.0 into 1994 3.0
dlevi2121
Brownsville
Is it possible to put a 1996 4.0 into a 1994 truck that had a 3.0 can I unplug the harness from the 4.0 Explorer pull the motor and put that down in the 1994 Ranger and plug the harness int the Ranger will this work or do I have to swap the whe whole harness? Thanks Dustin :icon_welder:
no you need the whole harness and the ecu go to the tech section and read some
I have been there but I dont see if there is any difrence between a 93 and 96 that is why I am asking here you dont have to tell me where to look you can tell me if you know the difrence or not but trust me i have read alot of diffrent things in here but i just want to make sure before I buy it so if any one can tell me what the diff. is in these to please do so i have looked in the tenc. lib. and dont see it thank you.
That stuff isn't usually covered in the tech library. The nity grity usually has to be covered here in the forums.
I once had a 96' 4L I wanted to swap into my 93' 2.3. I was misinformed and misread information about the heads being different and causing problems when using earlier management. WRONG> A 4L is a 4L and the chamber will only affect operation when the 95-97 heads are placed on a 90-94 block. The later pistons are more domed to compensate for the smaller chamber in the head.
Now as for swap specifics.
Upper Intake, etc: You will need to get a 90-94 Aluminum upper and maybe lower intake. You'll also need the fuel rail and fuel injectors.
Cooling system: A 3L radiator will work. You'll just need the hoses.
Exhaust: If you have a early 93' Ranger with a 3L you may be in luck that the y-pipe will line up with the 4L's exhaust manifolds. Later 93' and 94' 3L manifolds are different and so is the y-pipe. So you'd have to find a 93-94' 4.0 y-pipe (they do sell it brand new at napa). A 3.0 uses the same catalytic converter as the 4L. If you are wondering......"why can't I just use the 96' y-pipe with the swap?" You can't (or won't bolt up)because the catalytic converter flanges are different.
As for the manifolds, I'm guessing the 96' has EGR. Just get a set of earlier manifolds from a 90-94 ranger or explorer.
Motor mounts: You'll just need the passenger side mount. The driver's side is the same between a 3L and 4L.
Air-Intake: You'll need the air intake tube, MAF, and airbox from a 93-94 ranger or Explorer.
Fuel system: You'll need the fuel line from the fuel filter to the engine. I think 96's are the same as earlier models from the hard lines to the engine but you'll still need the hard lines from a 93' or 94'.
You'll need a 4L trans.
Wiring/Electrical: What will make the swap a very easy and "non-suicidal thought" experience is the correct wiring harness. Get a 93-early 94' wiring harness and PCM. You'll need the harness from the overflow tank area all the way around to the PCM plug in and where it plugs into the white cannon plug on the firewall. You'll also need the on-engine wiring. And the correct harness for for whatever trans you'll be running.
If you are serious about this swap I have the motor mount, hard fuel lines, Air box, MAF, Upper and lower intakes, fuel injectors, rad hoses, and a few other little odds and ends. As for the wiring, get in touch with AllanD.
