1995 Ford Ranger Problems
mitown
I got a 1995 Ford Ranger and when I accelerate it makes a loud rumbling noise coming from the rear and it doesn't make that noise in reverse. What do you think could be the problem. thanks
could be the rear end going out. try draining the fluid out of it and see if there is a lot of metal shavings or bearing parts in the fluid.
OK that's what I thought, I'll go drain out the fluid
sorry haven't got out side yet, its way to hot. I'll go out and check after the sun goes down then I'll let you guys know.
i have a stupid question where is the plug to drain the oil
