1995 4x4 ranger help?
rangerdude91
virginia
ok i been seaching the web for a week. all i want to know is if my ranger has torsion bars that i can tightening to level out the front and if so can somebody show me some pics or something in order to do it? ive looked at the diagram that is on here but is didnt help at all.
1995 ford ranger xlt 4x4 extend a cab
i dont believe you can raise your torsion bars to level your truck, because the have a twin i beam front axle. if you want to just level your truck the cheapest way i know how is to put washers under your front struts, and get new cambers.
You have coils up front, the torsion bars didn't start until '98. You can get a set of Skyjacker leveling coils, or use a spacer under the spring. As Black Ranger said, you will need an alignment afterward, and will most likely need new caster/camber adjustment bushings.
Spend some time here:
http://www.therangerstation.com/tech_library/index.php
