- Jun 1, 2013
- Automatic
I am going to install new rotors and brake pads on my "94 Ranger, add a new inboard bearing seal and grease the bearings. Question-- after everything is reassembled what is the procedure for
Tightening the castle axle nut to _____ and rotating the rotor clockwise, then after that I would back off the nut ______
and then install a new cotter pin thru the castle axle nut so that the bearings can expand and not bind when in use.
Any advice there?
Thanks.
and then install a new cotter pin thru the castle axle nut so that the bearings can expand and not bind when in use.Any advice there?
Thanks.
