For Sale 1994 Ford Ranger XLT 4.0 4X4 Custom (Seattle)
Eric H
5+ Year Member
Seattle, WA
1994 Ford Ranger XLT 4.0 4x4
Clean Title
2nd Owner
No accidents
Non-Smoker
Personal Use Only
Highest trim option available on this truck. Body is straight, no rust.
All modifications done myself during my ownership.
Comes with binder of progress photos and 99% of all receipts.
Everything works as it should -
Heat
A/C
4x4
Power windows
Power locks
Stereo
Pop-out Rear quarter windows
Engine Mileage - 245,xxx
Transmission Mileage - Less than 1000
Engine and Transmission
4.0 OHV - 245,xxx miles
A/T A4LD transmission - Less than 1000 miles. Remanufactured from Bullripper equipped with heavy duty torque converter and shift kit upgrade
Interstate Battery - Installed 8/2022
Tabs dated 9/2024
New heads with valve/rocker assembly
Upgraded rear main seal
New brake master cylinder
Upgraded 130 amp alternator from explorer (Original is 95 amp. Direct swap)
New motor mounts
New trans mount
Perma-cool Secondary remote oil filter for transmission Fluid
Rebuilt Ford powering steering pump
New fuel filler neck hose
Exhaust
2.5” catback exhaust
New catalytic converter
Flowmaster Delta 40 muffler
Chrome angled exhaust tip (welded)
Suspension
8” lift front -
6” Skyjacker lift coils
2” Coil spacers
4.5” lift back -
2.5” lift blocks
2” lift shackles
Skyjacker Extended sway bar end links
Skyjacker Extended stainless steel brake lines
Skyjacker Shocks front and rear
Skyjacker 6” Drop pitman arm
Skyjacker 4” Radius arm drop brackets
Skyjacker Steering Stabilizer
New Power Stop Brake Calipers (Red Powdercoat) (Less than 200 miles)
One piece driveshaft conversion from newer Ranger (originally 2 piece.)
MOOG tie rod ends
PML Painted Rear differential cover. Larger capacity with cooling fins
Redhead Steering Remanufactured Steering Gear Box
Borgeson One piece Telescoping steering shaft
2” custom BORA wheel spacers front - Made by Motorcraft USA
2” wheels spacers back
15x10 Aluminum American racing wheels AR-23 (No damage or curb rash)
31”x10.5” Tires - excellent tread left
Exterior
Projector headlights
Clear corner lights
LED headlight bulbs - S-V.4
LED switchback turn signals - GTR Ultra
LED Fog Lights
LED taillights
LED Third brake light
LMC Billet Aluminum grill
2011 Ranger badges
Tinted Windows
Smoked Window Rain guards
One piece Rear window Conversion
Low profile bed rail caps
Herculiner bed liner
Bullring cargo hooks
Interior
Summit racing seats (less than 500 miles in them)
Grant racing GT steering wheel
Pioneer Head Unit
10” Kicker subwoofer powered by 200w amp in shallow mount box
4 Kicker CS68 door speakers powered by a 600w kicker amplifier
80 Mil Fatmat Sound deadening inside all of cab
Redone black headliner
New Driver side window regulator and motor
*Seats sit high with current brackets. If you’re 6ft or taller you will need lower seat brackets or modify the existing ones.
Lots of maintenance parts replaced. Binder with progress photos and 99% of all receipts
Comes with Original owners manual.
Box with extra parts both stock and aftermarket including but limited to -
-2011 Retrofitted Ranger taillights
-Multiple new third brake lights
-New Clear corner lights
-Rebuilt Steering shaft with new rag joints
-Misc. parts and pieces
Turn-key, ready to go as is or a great project to continue building.
$16,500
  • 1994 Ford Ranger XLT 4.0 4X4 Custom (Seattle)
