1994 b4000 speedo
badmts
15+ Year Member
Lakewood Wa.
Is it gear like a t-5 foxbody or electronic? my tach works but speedo and odometer are inop. speedo was inaccurate anyway so is it as easy to adjust as the foxbody ? if i am goning to fix it i might as well get it to read correctly!
yours is cable operated
You have a speedo gear. it's located near the tailhousing of the transmissions. all you need to do to adjust it is to find the gear with the correct amount of teeth and install it. there is great info on it in the tech library.
