1994 2wd manual, hard shifting when cold .
remington115
15+ Year Member
So I just picked up a 1994 ranger 2.3l 2wd manual trans, I've noticed when cold some times it wont go into gear. I haven't checked the fluid yet to make sure someone didn't put gear oil in there. But I want to service the it any how. I know it takes ATF. I also ordered a Shifter Bushing kit, and plan on bleeding the clutch as well. My Question is that had an 08 tacoma 6 speed that had the same problem (i know completely different trans) and I used the Red line MT 90 and it shifted better then ever. Has anyone tried the redline D4 ATF? On the Redline Website when I input my ranger it recommends this new D4 ATF for the manual trans. Just seeing if anyone has tried this and has some miles on that fluid.
Also Read some people are running Engine oil 5w30 with good results. just want my trans to shift easy and not damage the sycros or gears
The redline has been used. I think it was plumcrazy that reviewed it for the M5OD.
Update Transmission definitely needed a Fluid change, I just went with trans fluid for now, Secondly the shifter bushings where shot and the spring washers were all mangled. it does shift a lot better. still sometimes doesn't like to go into first gear but it doesn't grind so my hope is that the first gear synchro is fine (wishful thinking), But i still need to bleed the clutch so maybe that's the little relief that first gear needs.
Not being able to shift into first at a stop is a thing with these, the gears have to be spinning for the synchros to work and for whatever reason almost every time first just stops when the teeth are lined up point to point...
I flushed the clutch fluid and re bleeded the clutch and it helped a lot more seems like there is more disengagement of the clutch and seems like it goes into first gear at a stop no problem now.
