1993 Splash build
1993 Splash build
1993 Splash build
1993 Splash build
Looks good, but your missing a few parts :D
SVT
Yea, a TrueTrac, Yukon 4.56's and chromo's, LONG's, brakes, and WARN hubs :)
True trac!!! That thing needs a locker. Looks good what's your width going to be I probably missed it.
Thanks guys. It's EB width ( 6" shorter ) And I'm really torn between a locker and a TrueTrac for the front end. I get some pretty shitty winters up here and want here semi-streetable.
Found a set of Eaton 16 bolt 15x10 beadlocks on CL today for $250. Anybody have any experience with these? NTWonline makes them and the outer rings look flimsy as hell.
You suck. You have all this awesome, pretty looking, stuff for your truck.
I have exhaust manifold gaskets catching fire and wheels flying off.
Some day's you're the bug, some days you're the windshield, my friend. You have to remember I flopped my truck a couple months ago. It will get better!
I really want to buy Micah's BII and swap EVERYTHING including the 4.0L drivetrain into it.
Just got back from a good score. Got a semi-complete corp.14 bolt and a 460 block,crank,pistons,cam for free and scored a set of 15x8 chrome wagon wheels for my SAS for $20. The little 2wd ranger did not like all that weight...
I heard the Tru Trac is good until 1 wheel comes off the ground, then it can be problematic. I've thought about a Tru Trac for the front of my F250, but it only sees off road out of necessity, not for wheeling.
I think and Eaton Posi would be good for the front. I love mine, although its in the rear. But it offers good traction and smooth operation.
Sent from my iPhone
Go locker, you won't regret it. In the snow I have no problems locked at all 4 corners, and you can always unlock one hub.
You need a locker chromos and good u joints your setup for it. Watch for a selectable I just picked up a zip for $400 new in the box. There's another for $500 near me too. I just think you'll regret a true trac.
I know. I'm just frustrated.
I still think about buying it too, but it has some serious hack work underneath. The bottom is getting rusty too, especially around the weld joints.
Okay, locker it is. If that's the case, I'm going with a Grizzly.
Would u ever consider a spool for the front? i have been driving aound with mine this winter and its not that bad. Just need to take it easy, plus their alot cheaper. Also your axle will be built for it with the shafts and ujoint u got.
I dont regret puting one in the front of mine.
