1992 Ranger 3.0 v6 v8 swap wiring
USA
I have a 1992 Ranger 2wd with a 3.0 v6, I also have a 1998 Explorer 5.0 v8 I want to do a engine swap, Not sure what wires I need to make it a stand alone wiring harness going from a 1992 to a 1998 or what they hook into. Do I hook the power wire from the ECU/PCM into the 1992 power source 60 amp fuse under the hood
any help would be greatly appreciated.
Is the 1998 still in running condition? if it is, I would start slowly loosening the 1998 wiring harness, see if you can keep it running by pulling some wires out of the way, but leaving the important ones. One at a time using a meter or testlight and a diagram. Get the 98 down to where it is still running, and you are confident to cut the cord so to speak.
pats or non pats
non pats....which you should have pcm made non pats if it is.
leave eec harness intact to pdb. retain power and grounds. hooking your crank and run power going to pcm diode in donor pdb. fuel system run off of pump relay/inertia switch.
pats or non pats
Okay Thank you
