cball917
- Jun 2, 2010
- Manual
i bought this truck for a fuel saver. got some issues that i would like to take care of before i put it on the road. the fuel gauge seems not to work right. it shows 1/4 tank when truck is off and when switched on bottoms below empty. it has a new fuel pump and sending unit less than 2 mths old. i bought a used cluster and still does the same thing. however when you remove the anti slosh mod from cluster it peaks out past full.?????
second prob is the temp gauge will move just a tad. after it gets warm the needle is resting about on the "c". it neer gets any higher?? i have a new sensor for it but i cant find where it goes. i was also going to replace the temp sender?/ i did not know it had these 2 different parts?/? any help would be appreciated. and yes i am a newbie thanks for letting me in
