I suppose its worth mentioning carc stands for chemical agent resistant coating. The key word there is coating, its not actually a paint. Its changed since the last time i used it but to my knowledge its still a solid suspended in liquid (i think water now days) the liquid is only there to make application easier. If you spray it use a cheap gun, its very abrasive and will tear up your gun.
thanks man. i think i am going to get some acrylic and spray it without any clear coat or anything, the paint will be full of scratches and scrapes so i am not going to be too particular about it
Okay so the stuff i am thinking of is still a 2 part mix, its still rather involved. If 383 doesnt get you anywhere try ppg code N1433A, thats an actual paint, its used touch up damaged carc. Its about as flat as flat can get
sweet, flat is good lol. thanks man i gotta check with one of my buddys tomorrow at the paint shop he works at so ill give him these numbers then. thanks again bud
Nope, they're still in pieces. Gotta get new skids on them, then drop about $1500+ into bearings, seals, shims, etc... Then i gotta sort out brakes. My list is about 4 miles long right now
For
a small yearly donation, you can support this forum and receive a 'Supporting
Member' banner, or become a 'Supporting Vendor' and promote your products here.
Click the banner to find out how.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
