- Aug 10, 2017
- Automatic
A little over a year ago, I purchased this 1988 V6 2.9L ranger with 119,000 miles. It had been sitting for 10 years without running so there were a few parts that I replaced (water pump, spark plugs, distributer, starter, high pressure fuel pump, fuel pressure regulator, fuel filter).
It has never liked to be turned on and off multiple times in a short time span (when running on low rpm it will suddenly drop and the engine will die) however it typically has done well on the highway or any time that I am accelerating.
The other day, I tried to turn it on, the engine turned over, and then immediately died. I tried again and tried to give it a little gas to keep it running, but it still killed itself.
I am not sure what the problem is, but am thinking that it could potentially be the low pressure fuel pump in the gas tank (that part was never replaced)? Unfortunately my new apartment complex does not allow for residents to do auto work in their parking lot so I am probably going to have to have it towed to an auto repair store to have any diagnostic work or repair done.
My questions are, has this happened to others before and do you know what it could be? Is this problem worth looking more into or is it a lost cause?
Thanks!
Thanks!
