1988 2wd front Ibeam camber problem
ronnie918655
10+ Year Member
Does anyone know of any aftermarket companies that make 3.5 degree offset camber bushings for 1988 2wd ranger? Truck has lift kit and drop i beam brackets and 2.5 degree offset bushings but still have positive camber. I need 3.5 camber bushings :bawling:
Did you put new springs on the front? If you did drive it around for a few weeks to let them settle and try again.
What adsm said......annnnd NAPA has bushings....
Checked with napa they say they only have bushings up to 2 degrees
