1988 2.9L Fuel Pump Sending Unit Ground
JerrySab
5+ Year Member
Los Angeles
2.9 V6
...Is there a specific location for this guy? Orange wire coming off of wiring harness. I keep losing it in the loom while trying to trace it back from wiring harness to its ground location. While 'look harder' is a perfectly reasonable response, would lvoe to see if anyone knows where it's attached. Wiring diagram tells me it grounds in the same place as the pump ground. I can't find em.
48592
Thats because Ford moved them around
Try behind the kick panel on passenger side, follow the pink inertia switch wire
The yellow fuel gauge wire and pink FP 12v wire along with the 2 ground wires are often found behind that kick panel
Then the 4 wires go out as a harness
RON D WITH THE QUICK ONE
Thanks man! I'll have a look.
