hello everyone, this is my first post on the forums that i have fallen back on countless times over the years, however i have a question that seem to not have been asked before.
i have an 88 ranger 2.3 with factory ac which has been converted over to r134A. my problem here is that my ac compressor clutch stays engaged 100% of the time when the "ac" button is pressed, and disengages when the button is off. i do know that 89+ rangers and bronco 2s have a clutch cycle relay, however my wiring does not have this; only a wot cut off relay.
my system does have a pressure switch, which is for 134A, and a "hot climate" orifice tube (since i live in Texas). my question is what is causing the constant engagement of my compressor clutch? is it the lack of the cycle relay, a pressure issue causing the pressure switch to stay activated, or is it the orifice tube?
is it possible to make a relay harness to let the compressor cycle?
im not 100% sure what defines a hot climate orifice tube, however i will say that the ac throws ice at me the whole time its engaged.
any insight would be very helpful, especially from a pre 89' owner who may have had this issue before.
