- Jul 1, 2014
- Manual
I found a egr solenoid that had a different base and made it work. The engine now has no egr codes. I also replaced the distributor and the PIP code is gone. I had one code left and it was the #42 o2 sensor indicates system rich. After consulting with my dad and the Haynes manual I decided to replace the fuel pressure regulator. Code 42 went away and the engine idles better. I'm waiting to see if this helps the MPG any. I also have a new CAT that has been on standby until I get the over rich problem fixed. Thanks for all the help I've received so far!
