1986 Ranger Turn Signal Issues
BoomTexan
Forum Member
Atlanta
Hey yall, the other day I was pulling a trailer with my truck, all lights working perfectly. At some point, my turn signals went out, with the hazards still kinda working. They'll randomly activate the lights permanently, and sometimes actually function as hazards.
I'm not familiar with the signal path here, so was wondering if there's a mechanical blinker component that I should be looking for, or if there's a relay. Browsing parts is getting me turned around, because some sites will have relays for my truck and others wont.
Could someone walk me through the typical signal path for the turn signals/hazards on an 86 Ranger? Just need some idea of what to look for, past that, I should be able to diagnose the issue with my multimeter.
There is a diagram in the tech library.
Or if you like operation charm has some info. under lighting and horns then turn signals
If you click on locations near the bottom of the page under "connector locations" it will list where like c201-at steering column.
Mike
Does sound like a bad relay or relay socket or connections to it. More likely relay as it seems like it's sticking on at times and not making the connection at others
If ya want to just throw a part at it…….
The turn signal/flasher relay is located in your fuse block. They are a mechanical relay that can and does go bad over time.
It’s the round looking thing about 1 inch in diameter.
Usually about $10.00 at your local parts house.
IIRC the only relay is the blinker module. Of which there are 2, one on the back side of the fuse panel in the cab.
If your trailer light connector is just wired into the taillights like mine is it could've definitely burned one out with the extra load.
Event Coverage
TRS Merch
