12 miles a gallon with a 2.3L 4x4 is this posable
Big Red Ranger
New Mexico
12 miles a gallon with a 2.3 4x4 truck!!!!!!!:bawling:
is this posable or is it a timing issue
Its an 88 and i just rebult the engine
any Help please and what can i do to fix it :D
It's possible.
I don't think it's right at all. I get almost 26 with my 2.3L.
Check it with a vacuum guage. You should read somewhere around 20 at idle.
regardless..you shouldnt get worse than around 20MPG with a loaded bed, uphill, against the wind.
timing is just one possibility. hows the power? any black soot/smoke from the tail pipe, especially after start-up? did you get all sensors installed/plugged in after having the motor out?
I'd suggest starting with the basics, compression and cam timing.
Then move on to the engine management system.
Something is definitely wrong somewhere. Unless, of course, you have 32" tires, 3.08 gears and constantly drive in 5th.
I average around 19mpg on my truck when I use the gas fast enough, right now I don't drive long enough for it to warm up fully (2 mile comute) so I'm always in rich mode and add that with winter gas and I'm getting 15mpg...
I have yet to pinpoint my issue fully, although I do have 165K on the engine, 31" tires (just under 30" actual height), 4 wheel drive, 4.10 gears and a couple cylinders a little low on compression (I think the lowest was mid 150's), I've been ignoring the CEL for a while now, so that'll probably help when I go to check it... :) it doesn't feel low on power.
same boat
new member and recent ranger owner and im having a real B!@ch of a time figger out where my gas is going i replaced all sensers new exhoust from header back new filter new pump and lines and cheaked all vac lines everything is perfect exept my fuel economy it suxs the gas hard i average 120km per tank down from 300km and i did some reserce and im suposed to go at least 600 km on a tank WTF!!!! im running a 1991 2.3l std reg cab 4x4on at the moment 28inch tires but the truck runs awsome 128 000 km oh ya top speed only 110 km
