100% gas vs. Gas with ethanol
My power equipment gets 89 only because that is the minimum octane specified by Stihl for their engines. The vehicles get 87.
I would prefer non ethanol but not at the prices they charge around here.
All gasoline has water in it, it comes from condensation in the storage tanks and transport tanks, then in the gas station tanks
Too much water is called "bad gas"
Gasoline and water can not bond/mix, gasoline is lighter than water so if allowed to sit in a container the water will settle to the bottom of the container, easily visible separation line
Storage tanks have "water traps" at the bottom, and are pumped or drain out often
Vehicle gas tanks don't have that
And fuel pumps suck in "gas" from the bottom of the tank
Gasoline has a very low freezing point, so winter temps are not an issue
Water on the other hand freezes at 32degF or 0degC
So any water in a fuel system will freeze at lower temps, and if its at the bottom of the gas tank or in the fuel filter..............well
Ethanol can bond with water, and when it does it lowers the freezing temp to at least -100degF
So its like anti-freeze for a fuel system in winter months
Ethanol also "boosts" the octane level of gasoline, this is why its also used in summer months, to bring an 85/86 octane up to the 87 minimum
Alcohol/ethanol can break down some rubbers, like seals, which is why it not great in older engines that used older seals
But new rubber compounds are OK
Ethanol has less stored energy per gallon that gasoline, so will have lower MPG, same as diesel has more stored energy per gallon so gets better MPG than gasoline
BTW, three years ago, filled a half gallon clear plastic liquor bottle (Yukon Jack) with a 50-50 mix of E85 and 93 octane. Put it on my shelf in the garage and just left it there. Never separated. Last year, put a few ounces of Marvel Mystery oil in it, to see if it would stay suspended. It has. Nice red color in the bottle from bottom to neck. Never seen one sign of any separation in the bottle in three years.
I just run whatever. I used to make a point to run ethanol free fuel but at a lot of stations it all comes out of the same nozzle... so if the last guy filled up with E10 and you choose ethanol free, there's still a bunch of E10 in the hose and pump. So I quit worrying about it. Maverick stations have 91 octane ethanol free but I have noticed that it makes my '88 run weird, and it definitely made my chainsaw act up. So now I just run whatever is cheapest, except 2 stroke equipment, which are run so infrequently that True Fuel or whatever makes sense financially.
For a vehicle you drive all the time, regular 87 octane with ethanol is fine, you burn the fuel up quick enough to not really have any water absorption issues. However, in something you only drive occasionally, or use occasionally like small engine equipment run non-ethanol. I just use the non-ethanol fuel in my lawn equipment, chainsaw, etc. Yeah, occasionally I'll top off the tank in my pickup when I go fill up the lawn equipment fuel cans, but I don't run it all the time.
I tried a couple tanks of non-ethanol fuel and didn't notice any difference in fuel economy in my pickup, just a slightly larger hit to the wallet...but that was before gas prices jumped back up to $3.35/gal again for regular...its over $4/gal for premium 91 octane non-ethanol fuel.
10 years ago or so I did some extensive testing with straight gasoline compared to the ethanol mix stuff (back when one could still find straight gasoline here) because I was studying the hypothesis that adding a little acetone to the gasoline improved fuel economy as well as keeping all the fuel system really clean. The results of my testing was that straight gasoline with a little acetone in it did improve fuel economy enough to be worth the hassle of adding it, but adding the acetone to the gasoline/ethanol mix made no difference in economy. Then they changed things so all the stations offer the gasoline including ethanol, so I quit doing it. But if I could get straight gasoline I would still be adding a little acetone to it and getting better mileage.
The gasoline de-icers like Heet are mostly methanol, since it will absorb the water and let it pass through the fuel lines without freezing up. Don't really need that stuff nowadays since the gasoline already includes ethanol which is much the same and absorbs water similarly but is a safer chemical to humans if accidentally ingested.
You really shouldn't drink gasoline no matter whats in it...
Acetone. Just buy Berryman's B-12. It has Acetone, MEK, Methanol and I believe Toluene in it. I use it occasionally, since I have a friend who owns a Sinclair station here three miles away. Sells 93 octane Shell V-Power and 110 Sunoco, at the pump. I buy the B-12 by the case full from him for a really good price. So I use it in the old Ranger a few times a year. Otherwise, I just pump a gallon of E85 into it at the halfway mark on the fuel gauge, then fill it with 91. Two gallons of E85 in the tank is right around 10% ethanol. Truck loves it, runs swell. Same as it does on 93.
Not to get all technical and stuff, but it is a Federal law (EPA) that all gas stations must sell at least 10% ethanol fuel for on- road use only. Similar to diesel fuel. It is illegal to run non-ethanol fuel in on- road vehicles. A law passed in I believe 2018 that required stations to sell 15% ethanol depending on some weird formula of supply/demand. I can find if anyone really cares. Ethanol fuel is supposed to be used within 2 months of coming from the station, it also suffers from what is called "phase separation" meaning the water separates from the fuel ethanol mix. Water is heavier than gas or ethanol so it sits on the bottom and is the first thing that goes into your carb. We know the only thing that burns water is a Stanley Steamer. You also must be aware that ethanol is "hygroscopic" meaning it absorbs water from the air, so your 10% ethanol you bought 4 months ago may be 15-20% higher in water content than what it started life as. As a career small engine mechanic for the last forty years, I have had my share of fuel related repairs. Oy, you got me started preaching.
So you're telling me that all the stations here that advertise NO ETHANOL, 100% PURE GASOLINE, and there are a lot of them, are lieing? Also, in Oklahoma, it is the LAW that if the fuel contains ethanol of any percent, it has to be advertised on the pump as containing ethanol. All the stations that advertise NO ETHANOL, their pumps have no such stickers. So they'd be breaking Oklahoma law if there is any ethanol in it.
Once again, OnCue stations here sell E85 with a yellow nozzle, E10 with a black nozzle, and 87, 89 and 91 NO ETHANOL with a red handle. It would be false advertising of them to sell fuel with ethanol in a pump, with another nozzle on the same pump that actually purports to be 10% ethanol. And another on the same pump with 85% ethanol.
Only if your running a sump.
Granted, if enough water gets into the tank, you are correct, but most draw straws and in-tank pumps are at least 1/4" off the bottom of the tank
And besides that, every time you fill the tank, you stir it all up. And when you are driving, especially if you live in PotHoles R Us USA, as I do, it's always getting stirred and shaken up. Just like all the bones in my body, every damn time I drive. Especially the Ranger, rides like a buckboard. My Lightning is a lot more forgiving.
+1
Basically don't run it in a carb that isn't ran often. It does not store well.
Advice I got a few years ago from the mower shop after I had carb problems was to put Sta-Bil in the gas ALL the time, not just for winter storage. Have not problems since I've done that.
Agree, in a modern car I don't think it makes any difference. Regular gas here has up to 10% ethanol and I often run E-15 since it costs 20 cents less. MPG seems to be unaffected. I did have issues with my old Sport Trac when it hit about 65,000 miles with the injectors being clogged, shop advised using a fuel system cleaner at every oil change and dry gas once in a while, I use Chevron Techron, after that I put another 150,000 miles on it without a problem.
I live in FL. There's E0 all over the place. It's 89 or 90 octane. I run it in all my power equipment, both two and four stroke.
My Ariens zero-turn has a supposedly ethanol-tolerant Kohler engine. I still buy the E0.
I can get it at Wawa or the Circle-K Shell station that's a little closer has Circle-K branded E0.
At the Circle-K, it's a separate standalone dispenser. At Wawa it's a separate hose on the MPD.
You find it in rural areas here in TN. Usually the dinky little stations.
