Saucer_Face
Hey y'all looking for some advice. I have 2006 ranger 4.0L that is consistently misfiring all on one side of the engine. The CEL is on for the misfires and a lean condition on that side.
Truck still starts and drives, but engine performs poorly, no power on acceleration.
I've confirmed the spark plug wires are in the correct order, and there is good spark getting to these cylinders. Plugs are new, so hard to tell, but look a bit blacker on the misfiring cylinders.
Compression tester shows cylinder 1 @ 75psi, cylinder 2 @ 80psi, cylinder 3 @ 100psi. Cylinders on the opposite bank are around 150psi (on average).
Leakdown test shows cylinder 1 & 2 to have about 45% leakage. Cylinder 3 @ 20%. Nothing significant found on the other cylinders. I could only hear air escaping on cylinder 1, and it was from the exhaust pipe. So I'm thinking that cylinder has a bum exhaust valve.
I'm wondering though, low compression on two adjacent cylinders makes me think head gasket. But I didn't get any bubbling in the coolant reservoir or rad with the leakdown test. I also haven't seen any other tell tale signs of hg failure: no coolant loss, oil looks normal, no smokey exhaust. Is it still possible to have a hg issue?
What about a timing issue? Like if the camshaft chain on this side of the engine was slack would it cause issues like this?
Thanks for any ideas you guys have on this.
