07 ranger engine/tranny compatible with my 02 B3000?
juntjoo
5+ Year Member
Cape coral FL
Do unto others...
I'm taking a look at an 07 ranger engine/tranny combo for sale. If it's compatible, how should verify its condition? Can you check compression by hand? I know you need to have it running to build it up but can you gather some info that way? What other ways can you check the condition of an engine. Only applies if it's compatible. And where do you check for parts compatibility? Thanks
You can buy a flexible shaft camera, attach to your phone, pull a spark plug & insert the shaft into the hole. you will be able to see the bores, combustion chambers. Look into Rock Auto catalog at both vehicles to compare the engine parts listing. Mazda V-6's were 2.5 & 2.7 and other larger ones. V-6 mills in Ranger were 3.0 and 4.0. Some 4.0 were OHC (German origin) and some were SOHC (Mazda.)
2007 Ranger 3.0l/Mazda B3000 will be the same as a 2003 Ranger 3.0l/Mazda B3000, so direct swap
Both will have
3.0l Vulcan engine
5R44E automatic, or M5OD-R1 manual
No other engine/trans combo would be a direct swap
2003 and 2007 3.0ls will use different engine wiring harness so you should probably swap over your 2003 intake, complete with injectors, to the 2007 engine, that also takes care of any Flex-fuel/gas only issues
No, not much you can check on engines and transmissions when they can not be run or driven
Check the smell and look of the fluids, that's about the best you can do
If its in a shop you can do leak down test with air compressor
As said above you can use a bore scope to check cylinders in an engine
Thanks guys. Turned out it was a 4 banger. I'll keep looking. Was a good deal though at $500. Or maybe not
