- Nov 8, 2016
- Automatic
So I have a 2004 Ranger Edge, 4X4 3.0, that I have had for almost 3 years. A few weeks ago it decided to not start up. I checked the fuses and even replaced the fuel line relay. No fuses were bad and the replacement did help. I wasn't to sure as to why this happened. I had a diagnostic test ran on it and a local shop, and the only issue they were able to find was the inertia switch had tripped. They reset it and it was running fine.
2 weeks later it wouldn't start after work one day. I tried to just reset the switch myself with no luck. Only thing that helped was the disconnection of the battery, and it fired right up. This happened 3-4 over a two week period. I called the shop back and they said I just needed to replace the switch. I got the part and had it installed, and went to make sure the battery wasn't going out since I never changed it. The battery was bad and needed to be changed out as well. The truck was running great for a week.
It died again, and this time I decided I would take it the local Ford Dealership thinking they new something I couldn't find. The only thing they could tell me was that my coolant reservoir was empty and a flush was needed to be done and it should resolve the issue. I did this, and was able to get home with the truck. It sat in the garage over the weekend unitl I drove around town all day with it yesterday. Got to the last place I was going for the day, and started the truck up. Very weakly it turned on for 5 seconds and then died. Tried to restart it 3-4 times no luck. Again had it towed back to my house this time. After sitting for a few hours I went back out with a code reader hoping it would tell me something. No codes, but 3 tries in it started up again.
At this point I have no idea what it could be. I have thought maybe the alternator is going out. I had a brother suggest the throttle position sensor. One of they guys at a local parts store said it was the ECM. I am at the point where I want to be able to test things before replacing them since I don't have lots of money to keep putting into the truck. So I was hoping that someone out there has ran into similar problems like this and were able to help me. I have a Code Reader and no Codes are showing up.
