- Dec 29, 2008
- Near Lima, Ohio
- Manual
Ok. This thing is acting up yet again. This engine has been a pain the last year or so for only 118,000 miles on it. Anyways here is the details.
It has a rough idle. When under load, say trying to accelerate from a dead stop it stumbles and bucks. Had it out Saturday and it back fired i believe a couple times. I heard a couple pops in the engine area or right underneath the front seat area. I pulled the air filter and it's got a little dirt but could see daylight no problem through it holding it in the air. Checked the butterfly on the throttle and i can tell it's running rich. It kicked the check engine light on and was flashing it Saturday. I got the codes pulled and it was these.
Cylinder 1 misfire,Cylinder 1 misfire on start up.
Plugs and wires were done last July. Replaced with motorcraft plugs for sure. Not sure on wires. Can't recall if i bought autozone or motorcraft off of rock auto. We also pulled the coil and tested it when doing the plugs and it tested good. (Learned my lesson on my Ranger, replaced plugs and wires when i got it and sure enough coil was bad too).
So any ideas what could be causing the misfire issue? We do routine maintenance on it. It's not every say 3,000 miles it gets an oil change but never goes over 4. I do have a fuel filter for it i just haven't been up to replacing it since surgery. I don't think the fuel filter is the culprit but figure it can't hurt to replace. So any thoughtsx or insight are appreciated. I have been reading and i'm thinking it's the cam snychro acting up. Seems the f150 had this issue with that engine.
2004 Mercury Monterey
4.2L
118,000 or a hair more miles on it
4.2L
