1988 V8 swap 4WD issues
TheDucksNutz
Forum Member
U.S. Military - Active
Arizona
7”
33"
I’ve successfully v8 swapped my 88. I’ve put about 4k miles on it so far and it runs great. Now I’m trying to fine tune everything and I’ve found myself stuck trying to get the 4WD to work. I have the electric push button system. My new transfer case I’m running with the motor swap is the bw44-06 electric shift. The electric shift motor from my previous bw1354 electric shift transfer case bolts on and plugs in to the original connector. Minus the green/ light blue wire magnetic sensor depicted in the photo. I’m assuming my issues have something to do with this sensor however I’m not sure. So I’m reaching out to the forum! Does anyone know how to get this set up to work? Do I need a different 4WD module under the dash? Do I need a different electric shift motor? Both? I’m trying to avoid cutting into my floor board and installing a manual shift lever.
  • 1988 V8 swap 4WD issues
What year and model did the BW44-06 transfer case come from? I wonder how that system sensed the front driveline turning or not turning? It would have had a sensor somewhere too I would think.
The extra wire is going to be for the clutch that sped up the front output so it is not important
If it won't work at all then I am pretty sure the shift motor might need to be aligned, unless it is looking for a speed signal that you aren't sending to the module, I haven't looked too deep into how they work.
