Aces Killshot Fusion EFI Swap
Fuel pressure is set, dizzy is locked down, plug wires are on and hooked up... start the countdown clock.
They want over 42psi, I went 50.
Plan tomorrow after work (I get off at 11) is to winch it outside, put the battery charger on it and clean up the garage and put tools away and if I can hold myself back work on the fan relays.
Then when I can't take it anymore we will see if it will do anything.
I know I'm a little late to the discussion, but I've found oddball half size wires is common in cheap applications like basic car audio. It's also usually copper clad aluminum. IE: CRAP.
For stripping I use a pair of Plastic Process Equipment gate cutters. Usually the 7" sometimes the 6". The blades are so soft it won't cut much wire before it it's a serrated edge. LOL. I've learned to feel the difference between the insulation and the wire.
