Body mount alternatives
Roert42
5+ Year Member
Kintersville, PA
Helping my brother work on his 96 supercab truck. Long story short we ended up unbolting the body mounts to lift the can, and now we need new ones.
Are F150 ones close enough they would work? Has anyone used an off the shelf body mount for something else and had it work with the rangers?
The only place I see OEM body mounts for the Ranger is LMC truck and they are not cheap.
Can find sets for an F150 all day for less then $100.
Otherwise I’ll just make something.
Yeah, I need a set for my '90 as well, the only kits I see for Rangers are poly, there's either black or red...
I used poly on mine and they worked fine.
I got mine off eBay.. brackets & rubber mounts pretty sure they were like 50 bucks a side. Reg cab though
So F-150 mounts aren't compatible?
Interested in a set of mounts for my B2.
No idea if they’re compatible (F-150) or not. Never compared them. I should have a box with poly F-150 mounts somewhere but I never bought Ranger ones. My Choptop has poly all the way around and my 88 will get poly, but those are Bronco IIs so there’s not really a good comparison.
Looked at the poly ones, but the Ranger ones seem much more expensive then the F150 ones.
We ended up using wood blocks for now.
Metal brackets are needing replaced too, so we’ll see what he wants to do.
