Rollalong Body swap
Rollalong84
EMT / Paramedic
Lagrande
OR - USA
Vehicle
2.8 V6
I bought this 84 roll along from another member and Im excited to get it going. Currently there are two issues that keep me from fully enjoying it.
1. Its 2x4 and needs to be a 4x4.
2. Its very underpowered.
I think im going to swap the body onto a 93-97 automatic 4x4 4.0 frame with a manual transfer case. I know automatics are hated but the cab is tight and I hate shifting when launching my Kayak on a boat ramp.
Anyone have any thoughts?
Edit: I'm swapping the cab and bed.
Im currently looking for a good donor in Eastern Oregon or Idaho if any one has a lead.
You could try different seats, I know with my normal first gen standard cab they have made a huge difference for interior room.
I don't know if just swapping in a later standard cab will really buy a whole lot of room.
Take a very close look at the two body types. I think there are differences in the body shadow lines as well as the lean back of the front windshield.
We do have another roll-a-long under reconstruction on here too:
I thought he was talking about putting the complete Rollalong body and cab on to 3rd gen frame. Sounds like a great idea to me.
I think he is wanting to do the cab as well though.
I don't really know how this thing is put together, it may be a very rare instance where it may be easier to weld the 4wd crossmember into the original frame than deal with the cut up pickup cab that is super glued to the camper body
@Rollalong84
Hello, I've never seen this set up before and would love to see some pics inside the back; is the cab a pass through to the rear?
I thought it was just a frame swap but either way I am with you, do a crossmember swap if the intention is to keep it TTB.
Dana 35 w/ 5x5.5 conversion and a full width rear axle & single tires in the rear would be pretty cool. I don't think there is truly a need for a dual wheel rear here.
This thing is just begging for a V8 swap or a small diesel... TDI and a GM automatic would be tits...
A concern of mine with my Skamper... I bet they have the stability of a wounded drunken water buffalo if a rear tire blows out.
I'm planning to swap the cab and bed.
this is clearly a case for sooperdoodie axles and a godzilla engine.
on that frame if it is not rotten... because it is made of better steel than anything post 91.
found the thread. welcome :) your undertaking should be ok to do if the frame lines up properly to the 84 cab and the camper part. that could be the worst part of it. I know the 2.8 is a bit lacking, however when i rebuilt the engine i was able to take the camshaft to a custom place a few miles from me and he gave me a nice torquey grind. the new engine humms decent. however does have a trade off of being a bit thirsty going up hills.
cheers
