Pic Request: 4th Gen Factory Jack
JMcFly
Maker of Things
⭐Supporting Member
Orlando
FL - USA
Vehicle
Drive
2.5 (4 Cylinder)
I can’t figure out how to store my 2002 Ranger Supercab Jack and assorted parts in the cubby. Can someone with a supercab of the same gen and interior style post a pic of how yours is stored
Thank you
you might be able to find a diagram in the owners manual if you have one. Also, 2002 is considered 4th gen in the Ranger world. with the option of having rear doors and different suspension than the true 3rd gens (93-97) the jack will probably store differently. otherwise, I can get a picture of my 97 storage if it helps, but I think the jack is different in 98 and newer.
AJ
4th gen, my bad.
No owners manual and the manuals I need finding online don’t really show any photos. I’ll have to keep looking for manuals or buy one off eBay
I can't say I understand how storing the spare jack would be confusing or hard to figure out, but I'll get you a picture up. I'm also lazy, so didn't take a picture of mine, but here's one I found online that matches.
I’ve got the super cab so it goes behind the passenger side fold out seat.
I’m particular and like to see how things should be.
That is from a supercab...
...a 4 door supercab. You are asking about a 2 door supercab. Got to specify to get the right thing. Heck, I tend to forget about the 2 doors still being produced in the 2000s
Unfortunately, I can't help too much with that one, I've never seen the placement for those to go look for a picture.
I’m new to rangers. I forgot there was a 4
Door variant.
If I remember right, my 00 2-door supercab had the jack in a clamp under/behind the one jump seat with the tire iron and the jack handles were in a cloth pouch just stashed in there
Should be like my '97 I would imagine, there's a clamp that holds the jack down and the lug wrench
Here's mine... keep in mind it's my commuter and well it's hard to get back there so I don't clean that... :), last time I did the rear window I just took the passenger seat out... Whether that setup is right or not I don't know, it's just what fit best, I didn't get it with a jack or lug wrench so pulled them out of the '94 in the junkyard I got the seat and door from... I think the clamp was there...
Thank you! That’s exactly what I was looking for.
At a glance that's identical to my 88. Now I know.
Ford at times was lazy and didn't change things that weren't broken but then would make yearly wiring changes for no obvious reason...
spoken like a man with a 97 Ranger lol
AJ
Meh, that one is fairly unmolested, my experience is more with the '90 that was built in '89 so it has a 3 wire oxygen sensor and random differences all over like the fuel pump wiring that was different than the '89 Ranger I got the frame from somehow... Having a '90 Ranger you have to know certain details before you order parts... heck the window regulator I just ordered is only '89-92 for some reason... probably the length of the shaft for the handle...
I do know that there are certain parts of the dash that are only for '96 and '97 even though it looks the same from '95 through '11, and all of the random differences over just the '95-97 year range... There's likely logic in places and I like improvement but dang, they even changed the shade of interior colors in '98 for the tan...
yeah, my 97 has specific to 97 cruise control pods. seriously. they look the same from 95 all the way up to 2008, but they are different electronically. ended up having to get a set out of a 98 and taking them apart to replace the crumbling and sticky original ones. also, the 4wd shift motor has a different plug in the 97 than the 94. same motor, different plug. From what i have heard from another forum member with a 97, there are other differences in the wiring as well that are 97 specific.
AJ
