2.5L ('98-'01) Oil Leak
Jay11
5+ Year Member
Texas
'99 4.0+'98 2.5
1998 2.5 2WD 129k miles
Has an oil leak, front of the engine towards the bottom. It's not dripping but the area is caked with oil wetness and mud. UT vids led me to suspect crankshaft seal needs replaced. Problem is when I search for the part on RA, Amazon, AZ, etc. all are giving me different parts (as in the part itself, not just the part number). Heck I am so confused. Which is the correct part number? Should I also replace the camshaft seal? I will be replacing the radiator due to a leak, TStat, serp. belt, idler, tensioner. Thought with the rad out might as well take care of the oil leak.
I just fell into a trap which may have caught you also. I looked up the timing cover seal, but found out they gave me the aux shaft seal. So that may be why you are getting different seal numbers for a "timing cover seal".
Of course all the rubber gets old on all the seals, you might as well change them all while you are in there.
Looks like a Timken 2955.
It's probably that or the housing that it mounts in, unless it's the O ring for the oil pump that's behind the aux shaft.
I didn't see a timing belt and tensioner in your list but would be worth doing while there
Starting to tackle this. Got the Tstat housing out and here is a close up of the leak. Where is the source of the leak and what should I be ordering to get this leak fixed? Initially I thought leak was lower but this area here has more oil wetness.
Any ideas, suggestions even what to look at for confirmation.
@[B]scotts90ranger[/B]
Getting the entire kit including timing belt and tensioner, etc
If the oil leak is above the thermostat then the only real source is either the cam seal or the cam pulley bolt, both can be tackled easily while doing a timing belt, if you pull the cam pulley off the seal is right there and the bolt just needs some thread sealant (permatex has some good thread sealant, usually in a little thing by the register at autozone or whatever, it's plenty). After putting that back together just let it sit overnight and you should be good to go.
It's either that or the valve cover gasket, I would probably do the above before ripping things apart to do the valve cover gasket, but at this point it's probably leaking too....
I am gonna replace the radiator due to a leak. I just flushed the engine but it needs more flushing. So I decided to add preston rad flush. I am not driving this truck unless its a road test. How long can the rad flush stay in without affecting anything? Specifically I won't be off to get to it until Thursday, flush and install new rad. If it's gotta be out asap then I can drain it on Sunday night. But can it stay until Thursday?
The instructions say run it 45-60 minutes and then drain it out. I would follow the instructions.
Got the engine clean, at least the caked oil grime. Well now it's too clean and can't see any leak sources-guess it needs a little more driving. One thing I noticed is tstat housing bolts were wet with oil when I pulled them. Not sure if it's something.
Oil Leak
BTW what is thing thing covered in aluminum foil (passenger side) and what is the purpose? I might have hit it with a pressure washer and caused a little perforation or may be it's always been like that.
Oil Leak
That's reflective insulation for something. Maybe AC or fuel rail? I doubt you hurt it enough to matter.
New Tstat & coolant installed after flush. Let truck idle for 15 minutes then drove it for another 20 minutes. Temp gauge stayed at levels below. Is this the normal range with 30 minutes of engine running? (Tstat failed open say 2 years ago, I just let it be. Gauge never moved of course, so I can't quite remember the normal range as such)
Oil Leak
Oil Leak
I would get a cheap thermal gun and check the engine and the radiator to see what it says.
First thing to check as far as operation, from a cold start make sure the top hose stays cold for awhile. After some time it should suddenly get warm. This will tell you your thermostat is working. If it slowly starts to get warm from the cold start, that means the thermostat is stuck open.
If that is working you should be able to measure the top of the radiator and the radiator hose, it should be 180-190 if you have a 190 thermostat in it.
The coolant temperature is read on the sensor on the thermostat housing, in the case of my '97 ranger I didn't have heat in winter but in the summer the temperature read low but more in the normal range.
After typing this up and going on a tangent I remembered that I also spent a lot of time on the thermostat housing, changed it, tried two thermostats. Turns out the Motorad thermostat doesn't fit the Motorad housing, the T stat won't seal on the ring it is supposed to sit against, I was able to use the Motorcraft T stat in the Motorad housing though.
It has a Motorad 306-192 tstat. I do have a thermal temp gauge. I will run the test.
The dumb part about this thermostat setup is the temp gauge relies on the thermostat seal sealing against the thermostat housing, the thermostat working correctly and the bypass going through the heater core or bypass circuit to get an accurate reading on the dash. If the thermostat is not sealing against the ring in the housing it will bypass to the radiator instead of the heater core or bypass circuit and the gauge will read low... also doesn't help if your heater core is plugged near solid making the bypass not work.
I've had time to think this through and understand it unfortunately :)
When everything is hanky dory is that gauge usual indication at normally a quarter, half or where generally?
