Needs some feedback on Door window mech (1994 Std Cab XLT)
ForgedCrank
Forum Member
Indianapolis, IN
Hi everyone,
I have an annoying issue with my DS window (manual crank). Every time I roll it down or up, the last 4" or so (at the top) causes a scraping high pitch sound. I've had the panel off rolling it up and down, but I can't figure out what is causing it and I don't want to start slathering lubricants all over it. It's almost as of the noise is resonating from the glass and that is making it hard for me to zero in on where it is coming from. There are no scratches on the glass (not yet anyway) to give me an indicators.
Can you guys tell me which pieces you would think are worth replacing to get this all back in order? The Ford manual isn't showing me an exploded view of the Ranger door with the part numbers, only the Aerostar. I'm looking at the LM Truck stuff and it looks correct.
Would you think that parts 7&8 would likely solve this? Or is there another known troublemaker that makes this squealing/scraping sound (it almost sounds like a "high ~D" note on a trumpet).
Front Door Window Components 1993-11 Ranger
If you do not want to make a mess with lubricants, how about a dish detergent or some other soap? It will at least change the noise temporarily and help you pin point what is causing it. If your wisker strips are worn it might be the window itself.
I would start low and work my way up spritzing soap and working it in the problem area.
You know I didn't really consider soap. I've made the mistake in the past of using lubricants like white grease and stuff to try fixing things like that and it works great.. for a short time, then it works more like glue and you can't get it off of felt and stuff. It's not a mistake I wanna make again. Soap wouldn't make it irreversible and can be washed back off so yea, I think I may try this when it warms up a little bit. Thanks for the feedback.
Silicone spray works excellent to.
