- Sep 5, 2025
- Bosque Farms
- State - Country
- NM - USA
- Vehicle
- Ford Ranger
- Drive
- 4WD
- Manual
- Total Lift
- 4
Im having trouble with my engine not running right. It takes a long time to start. The fuel pump kicks on when the clutch is pressed but shuts off when released. The motor runs rich and blows out alot of smoke. Im currently looking at the eec relay. Im getting constant power of 13 volts from the yellow wire, I get 13 volts from the red/LG wire when ignition is on. The black wire is grounded good. The solid red is getting 2.5 volts when on run. Not sure if that's correct. Can someone help me out with this.
