Heater Core Woes. Need Help.
StrangerRanger
5+ Year Member
First, I apologize is this isn't the right forum for this. I didn't see a specific "help" forum for this.
I have a 1995 Ranger XLT 2WD 3.0L M5OD tranny. I love this truck. I want to keep this truck. What I DON'T want to do is keep replacing the heater core. Once again, I will be forced to spend an entire day on a job that in most vehicles takes a few hours at most. (I can replace the heater core in my Mustang in under an hour) I hate this job. You hate this job. We all hate this job!
This will be my 4th heater core in the 26 years I have owned it. Each heater core has lasted less time than the one before it and I have spent the money on quality heater cores. This doesn't seem to have any effect on how long they last. I change the Coolant frequently and use the correct type. Doesn't seem to matter.
So, enough bitching about.
Does anyone have any experience on how to keep one of these alive? Is there a brand of heater core known for reliability? Is there a trick that seems to be working? I see some people suggest grounding the core. Others warn against grounding the core!
I am looking for first hand experience with this problem and what worked for you.
I know everyone wants to help, and I appreciate that. But I am looking for first hand experience, not what your brother's friend's dad did.
Thanks in advance. TRS has never let me down. You guys Rock!
Each heater core that was not very old and started leaking on my vehicles, it was because of me. I soon learned not to grab and twist the heater hoses when trying to get them off the heater core. I now always take a knife and carefully cut the heater hose and try to peel it off the nipple of the heater core, without any twisting action. Haven't had one go bad on me since.
Have you noticed a common point of failure?
I had a BMW 740 IL where I had to replace the radiator three times. The mechanic figured out there was some problem with how fluid passed to the reserve tank when it was hot and then was drawn back into the radiator when it cools down, which virtually eliminated the air pocket in the radiator. Without the air pocket, there is no place for the steam to expand, and it strains the radiator structure. It expands and contracts and eventually fails.
I would imagine those strains and stresses would be the same on the heater core if the radiator in your truck is not working properly with the expansion tank. Might be as simple as a new radiator cap. A cheap thing to check or try.
this job on the later trucks sux. but i have it down to an hour to an hour and a half with power tools depending on drain time..
having to pull that dash and from box is absurd compared to the original design which is literally a 5 to 15 min heater core swap.
i have developed a few dirty tricks cutting a few pieces and modifying it on the inside that so i can do it from the inside but its taking a chance at damage on reinstall from still being tight.
its a thing that sux. if it takes all day i can see being pissed.
in my case on the gen one my v8 pump was swelling the flow tubes and crushing the fins causing efficiency loss. and frequent replacements from low heat output in winter....something i was willing to live with...
these systems pack off easy...especially the bypass style. i suspect you have the bypass style to increase ac efficiency in summer.
if you by pass the bypass and have it full flow full time it may increase your service life.
if you can get some power tools it will really speed up the process...you can easily do this in 2 hours.
I’m really surprised that Bobby would modify one of his vehicles……
Mine was eating them when I had a 3spd, the higher flow from higher RPM's on the highway was doing them in.
Ford put a restrictor in the heater hoses on Mustangs to reduce flow, per a Mustang forum I snagged a 3/8 drive socket that fit in the hose and poked it in near the engine. Make sure you get the inlet to the heater core, if you go the other way it will increase pressure in the core. I noticed no difference in heater performance.
My last core straight up had a bad soldered joint...
I'm pretty careful with the nipples for the same reasons Franklin mentioned. Very easy to damage. If it's leaking elsewhere then I can't really give any other suggestions other than crappy parts. Even "good" ones these days can be questionable - you never know what you're getting. Radiators are the same deal, I have replaced a bunch of them that started leaking where the tanks are crimped after just a few years. Junk
You have me wondering if that's why the heater sucks so bad in my '86 with the V8 swap. It was never great with the 2.9 but it only gets luke warm at best now.
My heater has always worked awesome before and after I put 190* thermostats in it.
Per recommendations eons ago I initially after the swap had a 160* stat and it was a joke. I went to 180* and it was lukewarm.
Weird. I have a 180* stat now, I'm SURE that doesn't help, but the heat was pathetic before when I had a 195* stat and it still is. Heater core was new in like 2008/9... just never worked great.
I've just lived with it, the 180* stat helped a lot to keep engine temps down. It often stays between 180 and 200 degrees most of the year. When I had a 195* stat, that was pretty much the starting point and 210+ was the norm especially on the highway. On really hot days I still see some uncomfortably high engine temps but that is no longer a common occurrence.
Sorry for the thread hijack, carry on
I think the thread starter is gone.
I am finding out my 84 BII has a airflow problem in the plenum causing poor heat. I have a 2.9 in it with a 180 thermostat.
If you have the air going to the floor, you get very poor heat output. You must run the fan at least in medium. If you put the airflow lever in high/low, the heat is much better. You get a lot more flow with the floor and the panel vents working together. I turn the panel vents down to the floor.
This tells me the heater core is hot enough, even with the 180 thermostat. The problem seems to be restricted airflow through the plenum area. Try you heat in hi/low and see how it does.
Does anyone even know if @StrangerRanger is still a TRS member?
After reading what's in this thread I have a question.
However I don't know if I should ask it in this thread or start a new thread.
I will leave it up to you guys.
Do I ask it here?
Or start a new thread?
Do I ask it here?
Speaking from several years of experience, I think you should ask your question in any thread you want. My personal experience is that these guys don’t hesitate a second to slap you down if they don’t think you’re doing it right. But that’s just my impression….
I bought the 87 Missing Linc 2.9 of South Carolina in primer with a blown engine. I don’t know how long it was sitting, but after we got the engine and we got it running, I thought I had a mouse house in the HVAC system. After investigating further, I realized I didn’t have a mouse house, I had a tri level mouse condominium complex with a game room, a pool, exercise, room, etc., etc. After four years, I think some of it is still in there.
I used the combo of sucking with a shop vac and blowing with a leaf blower to open up the 97 4.0 a little bit before I realized somebody had actually cut out part of the ductwork behind the glove box.
I’m going to update the speakers in the 87 any minute, one is still working, and I’m going to dig in all of that when I take the dash out.
