- Jan 29, 2010
- Central Indiana
You might be able to fit the 10" wheels on the front. It would be tough with the amount of drop that I've got though. I'd end up running a spacer, and then probably rolling the fenders or doing some kind of mini flare. I prefer the staggered look anyway.
As far as the brakes are concerned, they're mustang cobra rotors, calipers, and pads. The pad does not contact the entire rotor surface, becasue it's not big enough. That's just the way ford designed them. The entire pad does make contact with the rotor though, and is moved as far out from the center hub as possible to provide as much braking force as possible.
