- Aug 21, 2007
Hey,
I am considering selling my truck, and would like your help ascertaining a fair price. Info as follows:
Basic Info:
- 1994 B4000
- 155k miles
- 5spd manual trans
- D35 in the front, 8.8 in the rear (open 3.73 front & back)
- White, extended cab with jumpseats
- Slider rear window
- A/C
- Electronic Transfer Case
Recent Maintenance / repair works:
- PS wheel bearings & spindle replaced with new (December 07)
- All u-bolts replaced (Jan 07)
- New ball joints (Jan 07)
- New front & rear leaf spring hangers (Dec 07)
- New leaf spring shackles (Dec 06)
- New Battery (June 07)
- Recharged AC (June 07)
- New exhaust spring bolt flange (Sept 07)
- Installed used T-case
- New drumbrakes in rear (Jan 07) (front disks both have above 60% left)
Upgrades / Mods:
- Full synthetic motor oil
- Fram Airhog air filter
- Manual Hubs
- Camo seat covers (Mossy Oak!)
- Sony Xplod MP3 headunit with aux input on the face (52x4)
- Pioneer speakers in back
- Kicker speakers in the doors
- Cobra CB installed, with cellphone looking antenna
- External PA speaker connected to the Cobra
- Tractor Supply Toolbox
- Ford Floormats
- Drop in bedliner, under the rails
- Four tie-downs, on the rails
- Tow hitch
- Skyjacker 6" springs, plus 2" spacers
- Skyjacker Drop Brackets
- Skyjacker Radius Arm Drop Brackets
- Skyjacker 6" Leaf Springs (on stock blocks)
- Skyjacker shocks all around
- Skyjacker braided Brake Lines, front & back
- Skyjacker Extreme Drop Pitman Arm
- Skyjacker Extended Swaybar End Links
- 33x12.5x15" BF Goodrich Mud Terrains, about 70% left
- Black rockcrawler wheels
- Flowmaster muffler, welded in (great weld job)
- One-piece Driveshaft
Would also come with, unintalled:
- Skyjacker Dual Front Shock Mounting Kit
- Skyjacker Steering Stabilizer Kit
- Limited Slip for the rear, from an '01 FX4
- Sub & amp, high quality but I forget the brands, plus wiring
- James Duff Traction Bars & various James Duff decals
- Skyjacker decals
- TRS member decal
Ive brushed & painted a lot of the frame & under carriage. Ive painted the bumpers and front grille all with the Autozone spray-in bedliner stuff. Its had regular oil changes by me, synthetic since I got it in Dec 06. I have worked on building it up for offroading, but never really found the time to, unfortunately.
So, what do you think it is worth? It does have a few small dents & dings. It has a little bit of over-spray around the grill (although I am sure it would polish out). It has virtually NO body rust (just a stripe on the tailgate, below where the bedliner rolls over the top). Its in pretty good shape.
I've got to swap out the Drivers Side wheel bearings & get it aligned, so those would be newly done too.
What would you guys estimate it is worth? Thanks very much, and please do let me know if you have any questions.
Here are some shots:
Title in hand, no complications.
Basic Info:
- 1994 B4000
- 155k miles
- 5spd manual trans
- A/C
Upgrades / Mods:
- Manual Hubs
- Ford Floormats
- Tow hitch
- Skyjacker decals
- TRS member decal
