- Nov 1, 2008
- Bellingham, Wa.
Hey guys. I finally got my gears in, and last night I got started on it, but ran in to a few road blocks. I'm totally new to this, but have read the directions multiple times, and done lots of internet searching. Here are my problems/questions.
1: I have my pinion set in with the old crush sleeve, and it's REALLY close to where it needs to be. My pattern looks great on the coast side (in the center both side to side, and top to bottom) but the drive side, is closer to the flank, and a little low. That tells me that the pinion is too high, and needs to go down, but wouldn't that throw off the coast side?
2: The reason I used the old crush sleeve, is because I don't have a good way to hold the yoke to keep it from spinning, therefore cant crush it.... I have the diff up on my work bench, and don't have a vice yet. Anyone know a trick to keep it from spinning without damaging the yoke?
3: At one point I had the pattern looking almost perfect on both sides, but the gears didn't want to turn. You could turn them by hand, but it took quite a bit of strength. When gears are new, is it typical of them to be kind of stiff at first or did I just have the wrong shims on the carrier bearings?
Thanks in advance! Any input will be a huge help
-Denny
-Denny
