Yea I we run alot of odysee batts in our jet-boats up here, the little tiny ones to save weight for fuel and meat. I have duels in my jet-boat with a perko switch and never a problem.
That is what I run, but I work for them and get a free battery each year!![]()
the new Optima are debatable.. i've had lots of local guys with extremely bad luck with them since that new-er company took over.. i had a yellow top die in less than a year, got it replaced and the new one is dead now.. i will never buy another one.. even tho they did make it right with a second battery.. the second time they said something had to be wrong with my charging system... and NO there is nothing wrong with my truck.. the new one has been fine for almost a year and still has great stats.
the duralast gold's have been great.. but the Zone didn't have the one i wanted so i got mine from advance auto, idk the brand but its a deep cycle marine/start battery... it was only like $78.99
Yeah I recently just picked up a new battery after researching... I was going to go for an Optima but I read all over that they aren't what they used to be, I ended up getting a Diehard platinum from Sears. It was like 180$ but it has twice the CCA's and a much larger reserve capacity.
If you want a cheap one then go to costco or napa and get a legends battery.
Since the OP is interested in a battery he doesn't need to spend a ton of money on I'm not going to waste his time by recommending an optima or odyssey since those don't fit his needs. I wish more people would read entire threads, including the OP's post, instead of just reading the thread title and posting something that isn't useful to the OP. -end rant-
I've been very happy with my Everstart Max. I picked it up from Walmart for ~$75. It has 1000 CA and 850 CCA. It comes with a 3 year free replacement warranty. It's been in the truck for a little over 3 years now and cranks right up every time, even in the middle of winter when the truck hasn't been driven in several weeks. I winch with it and run lights off it. I think that CA's per dollar this battery wins hands down, and quality seems to be top notch as well.
i've been using an Orbital (optima knock-off) for about 4 years. it's a marine/starting battery and about 850cca's. i have absolultly NO problems with it here in northern Minnesota where the winter temps have been as cold as -30. doing a great job. will be getting another one for my dual battery setup. and only $110.
