holyford86
Some guy with a problem
⭐Supporting Member
💻 TRS Socials
Boosted (Not Stock)
- Aug 6, 2007
- Age
- 40
- Plattsburgh
- State - Country
- NY - USA
- many
- Vehicle
- Ford Ranger
- Drive
- 4WD
- 4.0 V6
- Total Lift
- 7
- Tire Size
- 33x12.50R15
hey holyford,
did you notice any increase in mileage with the MAF system? how much work was it?
no huge increase in mileage with it, but it made the truck much nicer to run below 1500 rpm, it will lug way lower than it ever did with the speed density setup. It did seem to free up a tiny bit of power (maybe) and there is no comparison in throttle response. I was planning on doing some performance upgrades at the time i installed it (cam, headers) and the MAF setup would have adapted to those changes much better than the speed density would have (MAF monitors actual airflow, it doesn't infer engine load from manifold vacuuum).
It was relatively easy for me to swap, I had the speed density wiring diagram and the MAF diagram when I did it. I pulled the wiring harness of a 4.0 apart at the junkyard and pulled the MAF wiring right back to the EEC, so it was solder two connections and plug in two more. You also have to jump one EEC pin to another (I forget which two) to get rid of a code 41 (lean).
