Need help running my power wire
Musick17
20+ Year Member
Lincoln, IL
I had subs in my 2000 ranger and pulled them before i sold the truck. Now i have a 2002 and want to put them back in and cant find a sufficient place to run my power wire through to the cab.
My old truck was fairly easy to run through the fender and in through the door. The new truck has one tiny hole by the door coming into the cab.
I debating running down and then along the frame and coming up into the cab from the bottom but didnt know how that would work either.
Let me know what you guys have done with yours, It would be greatly appreciated.
Thanks
I drilled a hole in the driver side firewall, put a rubber grommet over the wire, then sealed it all in with Ultra Black RTV.
don't run it through the door if that wire pinches it can burn everything touching it
ran mine down the frame then up through the black ranger piece on the rocker
Firewall for sure.
Running it down the frame and up through the floor will work, I did the same thing in my truck. Came up right before the back wall
If you do it that way put an extra fuse/breaker a foot before the amp if you do off-roading so if somehow you snag or pinch it it wont burn up the wire..i've had this happen and its not fun
your main line going into your fire wall should have enuff space to put a hole in the side and run your line thur
