- Feb 24, 2011
- 1996 ford explo
my 96 explorer 4.0L has had an intermiten issue for a year
that seems worse when the temp is milder or the truck is hot. It starts just runs rough bogs,backfires etc never smokes though. Sometimes it stalls and wont restart(if you walk away and leave it for 30min it will start up and run perfect). Sometimes when it wont start the power locks will keep locking and unlocking when you are trying to start it. I have done fuel pressure tests,vacuum tests,spark tests all came out good and put close to $600 in sensors tps,crank,o2,map,idle control,maf,coolant temp sensor,egr,mudule,wires,plugs, etc! I have cleaned every + & - contact on the truck as well and checked all relay/fuses/wires for corosion found nothing.
When it is running it runs perfect no issues. When it acts up once you get it running and go 2 truck lenghts it smooths right out and runs great till you shut it off for anywhere from 10min -45min if it sits longer than that it does not act up!
anything that people suggest would be acting up all the time not just once in a while and only if hot and shut off between 10min-1hr any shorter time or longer time than that always starts and runs perfect. Plus if it was something else it would not smooth right out once you drive the truck litterally 2 truck lenghts. (wont smooth out untill you put it in drive and go have tried sitting with it running to get it to smooth out aand did not work have also tried reversing that also did nothing only works in drive) Totally messed up. I have talked to several mechanics ,and ford techs on numerous occassions they are all completely baffled!
