Cold Air Intake?
I have one on mine. Its called the factory airbox.
So your rocking out to stock setup. Right on. Anybody else on here with something aftermarket besides stock?
Not exactly a 'cold air' set up because of where the filter is but I have this. It's a Jim Wolf Pop Charger which is actually designed for a 1991 Nissan NX1600 I once owned just happens to fit the Ranger 2.9 MAF sensor.
Cold Air Intake?
the "brand" is me, i made it all and cut a hole in my hood for the cowl to gather cold air. it is one of the few aftermarket cold air intakes, that actually gather cold air
Cold Air Intake?
Cold Air Intake?
Cold Air Intake?
Cold Air Intake?
Cold Air Intake?
Cold Air Intake?
Cold Air Intake?
Cold Air Intake?
That's a considerable stretch of the term 'aftermarket'.:cool:
:icon_rofl: at least i'm not stretching the term cold air intake.
i guess it has 2 aftermarket air filters, and 2 aftermarket 4" mandrel bent elbows :icon_twisted:
this is the one my 84 had on it when i got it from my brother.
Cold Air Intake?
as far as i can tell tis just a crappy cone filter from autozone and about 4' of pvc.
Don't get me wrong. I thinks it's cool. (Note the smiley/icon) No direspect meant. However, if you look at my post you'll see that I'm not claiming mine to be a cold air intake.
i never thought you were dis'ing. i got what you meant. i was just commenting on how i didn't do what most guys do and take gauze, clamp-on air filters and put them on their rigs turning what was a stock cold air intake, into a warm air intake that picks up hot under-hood air
Looks good. I read somewhere that the cold air intake for the Dodge Neons fit the 2.9's as well.
I used a cold air intake pipe ment for a 1990 nissan 240sx...it is the same diamiter pipe as the hole on maf thingy....i did have to cut it down a couple inches, and grind a mounting tab off of it cause it rubbed on the rad. hose....but the pipe basiclly goes right to where the stock box sat behind the batterie
Any pics?
