starting issues
Cooter199
Hopland Ca
i have an 86 ford ranger 4x4 2.9l long bed dual tanks. i will try to start it in the morning and it just clicks but i can jump start it and for the rest of the day it will start perfectly fine i am complety lost. and ideas. thanks
Most times that indicates a weak battery from something taking electricity during the night. I have seen aftermarket radios do this. Also I have seen glove compartment lights not turning off.. Check it out.
It's possible dirty battery connections could do this also.
Big JIm
Mine did that. Got alt check good. But it was the battery overcharging the alt. Which ended up blowing both. Id bets it the battery like jim said.
i got a multimeter and was wondering how i can test my starter solenoid. and was wondering if i can test my battery cables as well?
Nope!
A multimeter will NOT test the amps that MUST be transferred by the solenoid.
If you are in doubt about a solenoid just getcha a new one.. they are real cheap.
Big JIm:hottubfun::wub:
ok tomorrow i am having my battery and alternator tested if they are good then im going to get new battery cables and a starter solenoid. if that doesnt work then probably move up to the starter. theres not a whole lot more it could be right?
it was my battery cables and my alternater. cabes had oil all over the inside of them and were coroded at the top and my alternaters brushes were horribly bad so i got a rebuild kit now it runs perfectly fine. thanks for all the help
