- Aug 12, 2007
I was hit from behind the other day with my ranger. It appears to be driving straight despite the hard hit however the bed appears to sit higher on the passenger side ( which took more of the hit than the drivers side ) and there is slight damage to the cab where the bed hit the cab albeit very slight. In addition using my hand i can get my fingers all the way between the bedside and cab on the drivers side and only 2/3 of the way in on the passenger side. While the bumper mounts are toast it appears that the frame rails are straight on the truck. What im getting at is does anyone have experience with this kind of damage?? is it most likely the frame is bent?? are there tabs that the bed mounts to that could be twisted that cause the differences in the clearances of the bed and cab?? could the bed itself be the culprit in this?
On an 11 year old truck despite the low mileage im figuring its not too wise to put a ton of money into it to fix it up..Im wondering if its not a total loss
