- Jul 18, 2008
94 ranger, 4.0 engine.
We occasionally get a no start condition when the engine is warm. It always starts fine when the engine is dead cold. It also seems to start fine if you let a hot engine sit for an hour or more. However, recently the engine has failed to fire when we turn off a hot engine for about 10-20 minutes.
I checked spark during two of the no start conditions. Both times had lots of spark as tested by my timing lite on one of the plug wires. Each time it wouldn't start we noticed that when it did eventually fire up, usually after we depressed the gas pedal to the floor for a few seconds, we could smell lots of unburned gas. When it fired up it would chug for a bit and then clean itself up. Seemed like a classic case of flooding like on an old carburetor car.
One other test I ran. Fuel pressure is fine, around 32, when the engine is running. Sometimes the pressure holds at 32 when the engine is shut down for some hours. Once it held that pressure overnight. But on my last test, around the time of the last no start incident, fuel pressure has been dropping to 0 quickly after turning off the engine.
The engine has never failed to start when you turn off a hot engine and restart it within a few minutes, say at the gas pumps. It seems it doesn't like to start after a 5-20 minute turn off. I'm thinking a fuel injector is leaking gas into the lower intake and flooding us????
