- Dec 12, 2007
I finally got an FM145 to put in place of the A4ld in my 90 BII. My concerns now are:
Flywheel bolts-The flywheel from the donor would not come out, will the old flexplate blots work?
Crossmember- Will I need to move the mounts on the frame? How do you go about it, if so?
Pedal Bracket- The pedals came from an '86, going into a '90, will that work?
Transmission/transfer case seal- I've the one from the 5spd to put in (manual shift), what is there to seal it? I didn't find any gasket or anything.
Fluid- I believe motor oil came out of the transmission and ATF out of the transfer case, is that right?
Thanks a bunch..
Thanks a bunch..
