93-97 suspension type?
fords4all
10+ Year Member
Do all the 93-97 rangers have TTB suspension or is that just on the splash model? Im looking to get a ranger to do some mods to, like a 6" suspension lift for 33" tires. Things I have read say that anythign above 4" causes problems on TTB rangers. So is TTB just the splash model?
Thanks.
All 4x4s have it, the 4x2s have TIB. Issues that can arise with the TTB system tend to get exaggerated with larger lifts if care isn't taken to prevent them. Read a bit around the forum so you know what you'll need and go for it.
i think the biggest problem that people run into once they lift their RBV's, is getting it properly aligned. as long as you use 6" coils with 6" drop brackets, and a pitman designed for a 6 inch lift, you shouldnt have a problem.
Where is that promotional poster for the TTB/TIB Geometery. :D
