- Nov 26, 2009
Isnt the 4.0 a bored and stroked 2.9
"technically" it is but it also has a widened block and a raised deck height to accommodate the larger crank
"technically" ? i think not, as stated countless times on this forum and even on this thread: the only same part between a 4.0 and a 2.9 is bellhousing bolt up. so it is not "technically" a bored and stroked 2.9.....not even close. the deck height is taller so the 2.9 dizzy shouldn't work. the cam gears are the same, but i recall even seeing a picture of a 2.9 dizzy next to a 4.0 cam sensor and you could see the difference in length the engine is taller, wider, and longer. the fronts of the engines don't even have the same bolt patterns for the accessories.
cologne v6s are not like chevy small blocks, where you could say "a 383 is just a bored and stroked 305" because those engines are identical inside and out except for bore and stroke
