Lowing Transmission
orangemachine
Anybody ever tried lowering the transmission after you have installed the superlift to help with the bad angle on the front drive shaft so you dont have to spen $400 bux on a new drive shaft?
i'm sure something could be done to it... i don't see why it wouldn't work. but don't quote me b/c idk for sure. i'm gonna look into some tho.
I said transmission i meant transfer case. Either way im gonna look at it tomarrow and see if i cant make a bracket and lower it.:icon_welder:
but don't lower it enough that it puts anything in a bind.. you need to lower it all together if possible..
or maybe do the same concept as a jeep motor lift kinda... pick the motor up and the trans and t/case down..
