I've been trying to discover more and more information about all this. I'm not so sure about doing it until I go ahead and pick up another vehicle for a DD. Here's the quote I saw:
Here's the link to the thread:
http://grassrootsmotorsports.com/forum/grm/v8-awd-ford-ranger/22358/page1/
I'm very interested in doing this because it takes away from having to perform alot of customization and fabrication to different things. I'm thinking that if I found a good sploder, I could possibly retain the EATC and other wondrous options they contain such as the 302 without having to swap it into mine. Of course I won't cut corners on finding a good sploder, but I'd like to keep the cost of the vehicle under 6K. I'm guessing it's safe to say reversing the leafs to go over the axle would be considerable as well? Also, I know that the box won't mount directly to the back due to the wider frame rails, but I don't really haul much weight in the box so the fabrication needed to keep the holes in the original box for mounting won't be much of a problem. Sooooo.... what do you guys say?
If you go extended cab the ranger body will bolt right onto the Explorer frame. it's plug and play. swap engine harness the body harness mates and all the body mounts are there. if you really want the regular cab you will have to hunt down the 2 door sport from 95.Of course if you go with the 97 Later you get the GT40P heads.
